Esox
- Sep 14, 2006
- 288
I need to replace the wood in the transom of my '97 Lund Tyee (Aluminum). After tearing into it I realize this is not going to be an easy job. The gunwales extend to the stern of the boat and are covering the top of the transom. In order to install new wood in the transom I will either need to remove the entire gunwale or cut a small section out and have it welded back together after the repair is done. Also on the starboard side I don't have access to the inside of the transom (to remove the bolts) because there is a gusset and live well in the way. The only way to remove the livewell is to remove the entire splashwell as it is all one piece. As far as I can tell if I remove the floor on the starboard side I will be able to remove the foam underneath and will have access to the bolts in the transom from there. Here are some pictures of what I'm dealing with. Any advice is appreciated. Thanks!
On the left side of this picture you can see the livewell blocking access to the backside of the transom.
Here are the gunwales at the stern.
Here are some more of the transom.
Also.....Is it common for a transom to be rotten in a 10 year old aluminum boat? I was shocked at how rotten the wood was since I could put all my weight on the engine when it was tilted up and there wasn't the slightest bit of movement in the transom.
