I purchased a 92' Tracker with a 40 HP Evinrude that must have set a while. I just had the carbs cleaned and reworked. Now when I start the motor with the muffs on, it will idle for a minute and then go to wide open throttle with out moving the throttle. When I cut the key off it still runs and sounds like it smooths out the motor. I can pull the fuel line to stop the motor. It's a 2 cyl and when I pull the wires one at a time the RPMs will drop back to about 3000. Anyone have any ideas? Could it be an ignition system electrical problem. I have checked the prices and found them to be very high when compared to other 40 HP motors. Thanks for any help to pin point the problem.
