I have a 1964 Johnson 5.5 horsepower motor. I had it out this past weekend and when I put it in neutral the motor would kill. Also once in gear it seemed to lag on power. At open throttle it seemed like it just wasn't getting a enough gas. I have replaced the the gas can, gasline and the fuel line in the powerhead. I added carb cleaner spray while running the motor and it seem to make it work worse and stall out.
In addition to the above repairs I have also done the below work.
I have also replaced the water pump (impellor) and replaced the lower unit seal as well.
I am at a loss as to what to do next and any feed back would be great as to what to do next.
Thanks
BTuck MN
Thanks
BTuck MN
