Ran the compression test on an '88 4.3 L OMC I'm having trouble with....
160, 162, 158, 165, 156, 0
I'm not sure if the ZERO is accurate...that piston is spitting water....how can i get the water out to accurately test it? i think it's dumping in from the manifold as i crank it....tried the drain **** on the manifold and nothing but i know there is water in there......any suggestions?
How are the rest of the readings? I was pleased how close they are at least....
Thanks
Thanks
