longshanks
- Jun 12, 2006
- 188
Hi folks
I'm running a 14.5' welded heavy-duty aluminum fishing boat. It's a 5 degree, beamy hull, with a small 'tunnel' in the last 20" or so of the keel, designed to run very shallow. I bought it with a 60/40 mercury 2-stroke jet drive (tiller handle), which I GPS'd at around 42 km/h wide-open throttle. This setup takes around 7 seconds to jump onto plane.
I recently bought a second motor for this boat, a 2006 50 HP Mercury four stroke prop motor. After taking it out for a test drive, I'm not overly impressed with the performance of it, so I thought I'd post here and see if you guys have any ideas on whether I can improve it, or if I'm out to lunch...
As the motor is run by a tiller, I have no idea about RPM's, ie. no tach. It sounds like it is running perfectly, but doesn't sound as if it is revving very high. Engine is mounted with the anti-ventilation plate level with the bottom of the keel. I have started with a pirahna composite prop, 12" x 11C. This setup takes around 10 seconds to plane, and my GPS'd top speed is 36km/h. Considering the 10 additional horsepower over my jet pump (40HP at the pump), I was hoping for something more like 50km/h. Is this unrealistic?
Any suggestions on where to head from here? I have considered installing a tachometer, but if there are obvious better prop choices, maybe I should try them first. Merc recommends a 11" x 12C prop, or thereabouts.
thanks in advance for any suggestions...
cheers
longshanks
cheers
longshanks
