Ihave a Mercruiser 4.3l. The engine was just replaced with a new block, carb, & many used parts. The mechanic finds no problems, but when I get it on the water, it won't start until I either prime the fuel pump by filling filter & line with gas or trickle gas into the carb until the fuel line pressures up. It will run fine all weekend, will run fine on monday for the mechanic, but come Friday it won't start unless I do the above. He has replaced the original fuel pump with a square box looking thing which sounds like a machine gun until it pressures up. HELP?
