Re: Vro Alarm
pardon me if I may. I have a 1990 johnson 40hp on a 90 bass tracker 17' pro. I have tracker marine control box and the alarm is not located in the control box, it's in a removable panel covered with carpet and has a three inch round plastic vent just next to where the control box is mounted. I had a constant alarm when ever the key was turned on, I thought it was my vro, but it was getting oil, so I new that was not the problem, then I checked my temp switch like the OMC manual said, ground to the block and it was suppose to cause an alarm but the alarm was already sounding off so I tested the switch in the hot oil with an ohm meter and it was ok. so then I suspected my alarm was bad cause someone on this forum said they do go bad, so I changed the alarm, which by the way they don't make one like that anymore, I got a replacement alarm from my local tracker dealer, hooked it up and still I had a constant alarm with the key on. then I had the boat on the lake (with the alarm unplugged account it was ear peircing) with a 50:1 mixture of gas in the tank and the vro also hooked up let the motor warm up a bit, ran it for about 15 minutes, then I plugged in the alarm, and it was as I said "ear peircing", I took off the motor hood, with the motor running I unplugged the vro wiring harness, and my alarm quit, I the took apart the heat temp switch and tested it by grounding it out on the block and my alarm sounded off. so I plugged the temp switch back in, put the hood back on. When I got home I removed all of the vro stuff and just run premixed gas. I'm assuming that I had a problem with my vro wiring harness which caused the constant alarm, I hope that what I did was right. I do have an alarm that works and I do not get a chirp when I turn the key on and it's the same vintage as yours.
Rick.
