85hp overheat,Cylinder leakage into cooling system?
Chuck Smith
I have a 79 85 hp evinrude. port side overheats..new h20 pump..new head gasket..have low 60psi compression on upper port cyl. have removed t- stat hose and found hot steam coming out of cooling sys..Suspect definate leak.. Any advise on where possible leak from besides head gaskes....And what years will powerhead interchange??Thanks Chuck
tashasdaddy
Re: 85hp overheat,Cylinder leakage into cooling system?
exhaust gasket.
