Ok i have a 79 fiberglass starcraft that is heavily oxidized. Should i use a heavy or medium cut compound? or rub it out with polish because of the gelcoat? and an acquaintence of mine mentioned i mite not want to use the regular rubbing compound because of the gelcoat and that i should use marine compound.Wouldnt that be the same as rubbing it out with polish(using a marine compound)?thats assuming the marine compound has a very fine grit...and if a marine compound even exists i dunno...help and thanx guys
