ole evinrude
- Apr 21, 2003
- 4
just bought this motor for my 13' checkmate, and got everything on the motor ready to go now, it idles at a constant rpm, but it just to high. rpm's to high to shift into gear.
is this as simple as adjusting the little brass 'barrel' on the throttle cable? would that change it so when your just sitting there running in neutral it would idle at a lower rpm?
this is the biggest outboard i've ever worked on, with 3 carbs, and don't have a manual jsut yet. i figure since all 3 carbs run off a linkage between them, there's got to be an idle adjustment somewhere prior to the carbs.
any ideas?
Thanks
p.s. the picture shows a merc 110hp, but i decided to bump it up a bit more.
any ideas?
Thanks
