Wont Start!!!
farrellmh
Hey boaters
i have a 1985 forester with a 3.0 mercruiser I/O ,, and i cant seem to get any spark ?? i put a new coil on ... what else should i try to determine the problem
thanks
Mike
rndcomp
Re: Wont Start!!!
What happens when you turn the key? Anything? Does it try to turnover?
farrellmh
Re: Wont Start!!!
yes it turns over fine i had a bad starter and solenoid which i replaced both and its fine....
thanks
Mike
Don S
Re: Wont Start!!!
Assuming it has a points distributor, do a full tuneup if it hasn't had one in a year. You probably have bad points.
But before you think that is the cure all, make sure you have power on the + terminal on the coil with the ignition switch in the run position.
BTW, you do have the safty kill switch key in don't you?
farrellmh
Re: Wont Start!!!
is there a way to test the points... i really dont have much experience with that type of system .... but i will check the power to the coil in a sec.
Thanks
Mike
Re: Wont Start!!!
Is there Power to the Hot side of the Points,..??..??.....
Is there a Good Solid Ground to the cold side of the Points,..??..??.....
180shabah
Re: Wont Start!!!
I don't have Don's crystal ball, but the tea leaves tell me that there is a Factory Service Manual in your future.
180shabah
Re: Wont Start!!!
Don't say that; abuse will follow...
I saw you took a beatin' on that the other day...
Re: Wont Start!!!
Ayuh,............ I saw that too........
It's Just Amazing,.......
Boaters who come here lookng to become Mechanics,.....
Are given, Freely, the Best Possible Advice there is in the World,........
Then they take a Verbal Dump into Your Hat.................:rolleyes: :mad:
'ell,........... I'm "Mr. Know-It-All" now............:cool:
