Re: Need help with motor year and fuel leak
Well yesterday I tried to start the motor about three different times through the day with no luck. I finally went out that afternoon to start it again and it wouldnt turn over. So I did me some praying for it and got an idea to pull the fuel line off the cylinder for some reason and gave her a pull to my suprise it turned over and ran for about 5 seconnds till it ran out of fuel
. I gave it a couple pulls to get to run some gas through the lines and then put the fuel line back on and she started right up, came right out of choke and sat there and idled and went right into gear. I then let it run and turned it on and off about five times and it fired right up everytime. So it looks like it has been fixed.
When I took the carb off I removed all the mixture screws to clean them counting how many turns and put them back like they were but does anybody know what the stock adjustment should be or where I could get a good manual. I think I have narrowed the motor down to being a 1982. Thanks yall.
