Hi everyone!
I am in need of some help with my 1988 Mercruiser 2.5 IO.
The motor was over heating while trolling or sitting idle but fine when the RPM's were raised. Someone said that the pick up in the lower unit was bad. I had it replaced and when in my driveway with the rabbit ears on it was GREAT. Never even reached 100 degrees
Now that it's in the water it over heats regardless of how high the RPM's are.
I removed one of the water pump hoses (one of the large hoses) and it was dry. I started the motor with the hose still off no water came out. It was still dry.
I don't know if the water pump in the motor itself now has to be replaced...
I removed the hose coming from the lower end where the pick up was replaced and started the motor and still no water from there.
Does it need the motor pump to actually draw water up?
Can anyone give me some advice as to my next move?
Thank you Very much in advance!
Mike F
Sacandaga Lake
Upstate NY
Mike F
Sacandaga Lake
Upstate NY
