Mercruiser 4.3 Setting base timing.
JoeDemaree
Hi all I have just rebuilt a GM4.3. The engine has no mechanical advance. Just wanted info on the proper way to set the timing before i give it back to the buddy. It looks to be all electronic advance. It is a 1992 carburated model. Thanks in advance
Don S
Re: Mercruiser 4.3 Setting base timing.
Nothing special on the Thunderbolt IV ignition which is what you probably have on a 92, just aim your timing light and turn the distributor to set. Just be sure the advance works as rpm increases.
JoeDemaree
Thanks for the input. What would you set the base timing at.
Don S
8? Btdc
