cdnboatguy
- Jul 2, 2007
- 2
Hi everyone:
I recently got started working with marine engines.
I have a 65 Hp merc outboard. Not sure on model number but can get it if its important?
I discovered the cooling system was not functioning. "After it got very very hot."
I tested the compresion after discovering the heating issue. I think I caught it in time.
Cylender compresion is as follows
Bottom: 150LBS
Middle cyl: 135LBS
Top Cyl: 130lbs
After replacing the water pump propellor I put the boat back in the water for a test. It now doesnt fire on the top cylender when in the water.
All cylenders fire when out of water.
I suspect my problem is in my plug wires and or distributor.
I have replaced the plugs as well
Can anyone tell me if I am on the right path? or should I be looking elsewhere??
thanks in advance
Bottom: 150LBS
Middle cyl: 135LBS
Top Cyl: 130lbs
thanks in advance
