sony224422
- Jul 15, 2006
- 67
Re: 1989 150GT Johnson
you should consider having 2 batteries if you keep electronics on all the time without the engine.
A simple 1, 2 or both switch and 2 batteries plus the wiring and you're all set. Its what alot of fishing boats do so that if theres ever a dead battery they can switch over to start again.
If you don't keep electronics on with the engine off, the battery should be more than enough, as the electronics would be running off the alternator while the engine is on, not the battery itself.
