I have a 1997 Mercruiser 5.7 Alpha 1 that I just changed the manifolds and risers. I had the outdrive pressure and vacuum tested at the dealer over the winter, they also changed the water pump. Put the boat in today and when I run it up on plane it immediately ovberheated. I let it cool and got back to the dock. I pulled the thermostat. Ran it out same thing. the risers are getting hot also. Noticed that the temp went from 130 to 200 to 130 in seconds. I suspected that the water pump is sucking air. I replaced the water line to therm housing with a clear line and sure enough when I run up the rpms over 1500 or so i start getting bubbles in the line, at 2500 to 3000 I get large (golf ball sized) bubbles and the water velocity doesnt seem to have increased much. Do you think that the water pump may have been put together wrong? Is it normal to have any air in this line? How could air get in this line? water pump output tube? gaskets?
Thanks for any ideas
