Prop thrust washer
compfast
Does anyone know if I need a prop thrust washer on this lower unit?...see link and photos............not sure if this is optional .Thanks:D
http://iboats.com/mall/partfinder/?*******=865170705&gd_grid_id=223&gd_poid=111401&gd_row=1&keywords=prop%20nut%20kit&**********=913529885
...Lower unit with out prop off
...Lower unit with prop on
Re: Prop thrust washer
In a word, Yes. The thrust washer goes on first, then the prop then the spider washer then the locknut. The tapered side of the thrust washer goes against the taper on the prop shaft. They are available in many marine places.
Texasmark
You can clearly see the taper on the prop shaft just behind the housing. Without it (The washer) the prop will move forward and grind into the back of the housing......obviously not good.
Mark
compfast
Thanks alot guys , that would have sucked to not have had all the parts lol ........Thanks:D
fst929
I am replacing the Prop guide collar (aka thrust washer) on my 1980 9.8 hp. The dealership told me the part for my year/model was no longer available from Mercury. They have two of them on hand though so I will be grabbing them both tonight.
anyone know how often these wear out or what causes them to??
Texasmark
Never wear out. No mechanism for wearing out. Made of bronze which resists corrosion also, so that's not an issue.
Mark
fst929
Turns out it was not the washer...it was prop hub. The rubber was shot....
thanks for the info!
