Bimini Top Help - Windshield Mount
Sea Ray
I am looking at getting a Bimini Top for my boat. I would like to mount it on the windshield so that it is more centered over the seats.
The boat I have is a 1999 Sea Ray 210 and the windshield is pretty robust so I don't see that mounting there will be a problem. I see that many newer boats also have them mounted there, including the newer Sea Rays.
The problem that I am having is I can not find the windshield mounting hardware. I have been to local boat dealers, called a Sea Ray dealer (200 miles away) and look through the internet, including iboats but no luck finding decent mounting hardware. It is a Taylor windshield with a rounded top.
I would like to order the "rattle free" ball and socket hardware. I have been told that this is the best but I am open to any input.
I would also like to get some opinons on whether a 6' or 8' top is best for a 21' boat. I am going more for function then appearance.
Thanks in advance!
Sea Ray
Re: Bimini Top Help - Windshield Mount
Surely someone out here can help??
Can someone give me a brand of boat that has these mounts? Maybe I can order directly from a boat dealer?
Any other ideas?
Thanks
scoutabout
Sounds interesting. I just assumed I'd have to drill into the frame to mount which I'm not looking forward to. Are you saying this is something different? Have pics or anything?
lrlima
i just mounted a top to my winshield using the brackets that came with the top. I was lucky as the bracket was the same width as the winshield aluminum. I beleive there is also a side mount available...but if your windshield frame is rounded, it might not work with a specialty bracket. Pics of your setup may help
scoutabout
But what holds the bracket to the windshield on your boat? Did you have to drill into the frame?
Sea Ray
Here are a few pics of how some boats have the bimini top mounted on their windshields. I found these pics on e-bay. I haven't actually seen the boats and there isn't much detail to the mounting bracket. That is where I need the help.
It looks like all of these windshields are simiiar to what I have.
salty87
have you tried taylor made? they make bimini's and lots of windshield parts. google them.
tashasdaddy
8 foot i have a 6 an too small, it is mounted to the frame with deck type connector.
Sea Ray
Yes, I did try the Taylor Made website. I didn't see this kind of hardware on the web site. I even tried calling the number listed but it didn't connect??
OK, 1 vote for an 8' top. any other suggestions?
