Re: Gas/oil mixture
OK, there you go. That's a 1969 3.6 hp outboard, made by Eska. It has a Tecumseh powerhead.
The fuel
il ratio should be 16:1, using the type of oil used in chainsaws, not outboard oil. It's an air-cooled engine.
You can go to www3.sears.com, insert the model number like this: 217.58511
You'll then be able to see parts diagrams and parts lists. Sears may have some parts for this engine, but your best bet for most things is certifiedpartscorp.com. Call the number you find there and give them the model number of your engine. They have most things. If you have the part number from the Sears web site, that will speed things along.
Sears doesn't list what spark plug that engine uses, I'm afraid.
