dvan1901
 - Mar 26, 2006
 - 503
I have a 4.3V6 (GM based) and when I initially put it in the water it will start right up.  However, lately (last two times out) after I've been running it for a while (skiing and such) and then I go and anchor for a while, it is hard to start again (harder than when it is cold).  I did some research on the site and found where it may be a gas vapor issue.  Whenever I anchor, I let the engine idle for several minutes while I set the anchor and such which allows the engine to cool down a bit.  Just wonder what the issue could be here; if it is still a vaporing issue, how do you fix it?  It hasn't always done this so I'm a bit at a loss.  Thanks!
