Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
too easy...... a rigid three point harness would work....the small aprature at the trailing end would probably shoot the tail farther....but a rigid harness is the key.
after i get done my project... ill give it a whirl......it will be fantastic for jet fleas
This post is still going around! How many people you think are towing around soup cans as a result of this thread. I'll keep my eye out for you poor souls with soup cans.
I think someone should run two inch PVC along the side of the boat end that pipe with a 1 inch reducer going to a 45 angle out of the water. if that doesn't work nothing will and this thread can die a humble death.
Ok guys , in Bush gardens tampa the is a coaster called Shiekra after the second drop the coaster goes in a tunnel and there are two jets that shoot out water all over the crowd !! it was shaped like a scoop with the top out !! do you guys know what i mean ?? think we need to go with some thing like that !!! john
