Rough idle fuel leak found
izu
I'm still trying to id the problem on merc 115 hp
There's a constant drip at this screw. (3) Back drag carbs
The-Machinist
Re: Rough idle fuel leak found
I cant see much from your picture, but any and all fuel leaks should be fixed at once. Unless you like things going BOOM on the back of your boat:D
hope your fire extinguisher is in good shape:eek:
izu
Screw # 25 has a constant drip every 20 to 30 seconds. What can I use to stop this leak, Teflon tape?
I just finished cleaning all 3 carbs and installed items recommended: inlet neddle #6,7,8,33, blew it all out with compressed air.Reinstalled them (3 carbs) and when I pumped the primer bulb gas spray right out of the carbs. So I am in the process of adjusting #4,5 as per the repair manual. Measure 3 x's and hope for the best. Looks like its gonna be an all nighter.
Oh by the way I found a red plastic tube the kind used to attach to an aerosol can behind the middle carb it may have prevented #20 from closing properly.
Scaaty
Had the samo-samo...tighten up screw #16...top of fuel bowl.. Still leaks?.....new seal..( snug ONLY..do the rest too..)
izu
I wrapped it (screw #25) carefully with Teflon tape filled the bowl with gas left the float out and put the cover on, to test it..!! Should know if if gonna leak in a few mins.
OK it stopped leaking. Not a drop and when I pressed the primer it was very firm less than 1 pump. 7:30am its time for bed....I'll start her up later.
