I have a 1979 Mariner 140 hp outboard. The engine starts and runs strong - but here's the problem - Intermittently the engines stalls because it is not getting fuel. You can see the primer bulb go flat as the engine is not able to pull fuel into it.
You can sometimes keep it going by manually massaging the primer bulb to inflate w/gas - but having someone sit in the back of the boat and fondle the bulb is no way to go through life - and it's not guaranteed to work since sometimes you just can't get the bulb to fill again until you shut the engine down for a short time.
Here's a rundown of what I've done so far:
- When this first happened we though it was the fuel pump - so we rebuilt it - result - no change
- Next we hunted down and replaced the fuel lines and the fuel filter/water separator - even digging into the tank to replace the line that sits in the tank
result - no change
- Next I went out and bought a new 6 gallon external tank and hooked it up to bypass the internal tank.
result - things went well - for about 15 minutes - then the same thing started happening again.
Does anyone have any ideas on what could be choking off the fuel supply? Could it be the carburators? I'm at a loss since everything runs smoothly aside from the lack of fuel delivery.
Any help is appreciated.
Thanks -
Gary
result - no change
Thanks -
Gary
