Re: 2002 Merc. 115-will Not Go Over 4000 Rpm
PHILLY9,
I got your PM but it has taken a while to respond due to a recent illness. The issue sburdy brings up is valid and is a possiblity. Still, you need to troubleshoot it to at least a basic degree where you know whether it is a "fuel" or a "fire" problem. It could be either since we are talking an outboard which is 5 years old. The rubber in those fuel pump diaphrams does not last forever and COULD be your problem. Still, your particular engine's ECM has host of sensors it relies upon to set idle and engine timing. There are 2-3 fault conditions (in the ECM) which will cut power to one or two cylinders and limit your rpm's just like what is hapening tp you right now.
If you haven't already had it to the shop for troubleshooting, you are not out much $$ by simply purchasing a new low pressure fuel pump diaphram and seeing if that cures it. If not, the ECM is quite likely getting a faulty input from the Crank Position Sensor or the Oil Pressure Sensor ....OR...the ECM itself is faulty and must be replaced. Unfortunately, this engine is not that easy for a backyard guy to troubleshoot electrically. Not becuase you don't know what you are doing but rather, you need a whoe host of SPECIAL Mercury wiring adapters. These various adapters go between a standard digital multimeter and the wiring harness.
If you want more specifics on what I am saying, just look at an official factory manual for this engine and go through the elctrical troubleshooting procedure. You will see listed no less than 5 special adapters you must use to isolate the multimeter to the correct wires in the harness.
GOOD LUCK!
