Re: Throttling up motor dies.........
runs fine otherwise...........do you mean she dies if you put the hammer down from a standing start? Can you get her up to WOT at all? Before you order your carb kits, check the throttle/spark syncronization like seasport describes, also note that the timer plate has to start moving *before* the throttle valves start to open else she'll fall flat on her face.
Might also check the fuel lines.......does the fuel line hold pressure? Is the tank vent open? Fresh fuel?
Have you done a compression test recently?
No other symptoms? Any recently completed maintenance?
