Best way to change oil
TBarCYa
It's time to change the oil in my 1975 Mercruiser v8 Ford 302 so my question is what is the best way to remove the old oil? I'm reluctant to allow it to empty into the bilge unless someone can suggest one of those absorbant mats that will hold enough oil so I'm guessing that my only option is a pump. If there's another option I'm willing to look into it since the pumps cost more than the oil and filter for my change.
Another question I have is how much oil goes into this engine and does it use the same filter as the same engine in a truck?
smithrock
Re: Best way to change oil
What I do is, drain into a doubled up plastic trash bag. (No I don't then just throw it in the trash)! this works excellent for me--NO MESS !
laurido92
I had an oil pump you use with a drill. Run the engine with muffs for about 10-15 mins, until the oil warms up and then pump it out. It's nice and clean and you can use your regular oil pan. I bought mine for around $20. They're pretty easy to find.
Good luck
jontoronto27
Get a pump. It's sooooooo much easier, I just jonesed my own extra fitting (if you're near a Princess Auto you can get the pump with the fitting for $9.99. Just put the other end of the pump in an empty jug sit on a rear seat, enjoy the afternoon.
1974 Ford 302 CID takes 5 U.S Quarts (6 if you're replacing the filter as well). Now the type of oil you use will very greatly depending on who you ask. Seloc says
32 Degrees F and above (SAE 30)
0-32 (Sae 20W)
0 and below (SAE 10W)
As for the filter.. I just put a Fram Double-Guard in mine.. haven't had a problem.
TBarCYa
Ok so straight 30 no multi-viscosity oil seeing as how I only boat when it's above 32 degrees. It's most likely the PF1 filter if it's a Fram I think but I'll check the book to be sure.
If I can get the pump for $10 then I'll definitely go that route. The pumps at the marine store are in the 40+ range.
Thanks.
jontoronto27
Thanks.
Yeah I went to West Marine here in Toronto, 49.95 for the "Oil pump out kit" which was in there own West Marine Packaging. I ended up going to Canadian Tire and found THE EXACT SAME PUMP except this one was in plastic, and included an air fitting for pumping up bike tires as well, I paid 18 for that, later found another pump, that worked even better, and.. oh for pete's sake.. it's now $6.99 http://www.princessauto.com/_osn.cfm?CTRY=CAN&output=OSN&SRCH=1&SRCHAREA=OSN&T1=TRANSFER PUMP
If you're in the states, that's even less for you with exchange.
hal2814
I do the same as Smithrock. I've got a trashbag in a shallow box. Drain into that, pour into an oil pan, and off to the auto parts store to dump it when I'm done. I reuse the bag and box.
riverjet502
I had the local hydraulic shop make a 3/8 hose to fit my oil pan drain hole. (the oil pan has a 12 an fitting, "Milodon" oil pan) Bushed this down to 3/8. Slip hose through the bilge drain plug hole and then unscrew the cap on other end of hose and let it drain itself into a 5 gallon bucket lined with three trash bags.. Piece of cake....Oil filter is remotely mounted on transom... Piece of cake to change too... and no messes to clean up either....
DayCruiser
Ensign
When in the water, I use the pump I bought from northern tools catalog. That pump has come in handy for pumping out water too. They have battery and manuel pumps. Out of water during winterizing, I let it drain out the bildge into a bucket. Anyway, whatever floats your boat :D
Rob454
I just bought a harbor freight tools electric pump. The pump was 20$ and the hose and fittings ran me another 10$. this is the same pump that is used on the 150$ oil changing kits.
its SO much easier to change oil.
I woudnt trust trash bags. All I need is the corner of the bag to snag on something and I have 5-6 qt of oil all over the boat.
I was thinking of doing the drain hose in the old plug hole trick but my drain plug is part of the oil dipstick so I cant do that
Rob
