Ok, my 85 Force 125 is running pretty well for the most part.
Now and then my heat alarm will go off. Its usually when we do stuff like waterskiing and I have the boat in gear and just at idle circling around to pick up a skiier or whatever. If the alarm sounds and I put it into fast neutral, it will stop within a couple of seconds.
It seems to me that just not enough water is flowing when the engine is at a slow idle. Idling in neutral seems to be at a higher rpm and I have not noticed any problems.
I did check the thermostat and it seems to open up the whole way when I put it in hot water.
I am guessing I need a new impeller. My question is how difficult is it to replace that? Is it just a matter of dropping the lower unit and putting in a new one or is there a bunch of stuff that will need to be unhooked first. Also any special tools required? Will the prop need to be removed? What seals if any will need to be replaced before bolting it back together?
I have plenty of experience with car engines, but very little with an outboard.
Thanks
Jeff
Thanks
Jeff
