First timer here. Very impresed with the knowledge displayed. Wow!
I need you guys ...My local $100/hr mechanic recommends I find the deepest part of the lake, unbolt my motor, give it a shove, and buy new. Hope you guys can save me!
Patient: 1986 Evinrude 150XP seriel number E150stlcdc
Symptoms: After work described below, this motor will always run great at idle and intermittantly/frequently at full speed (48mph) then out of nowhere hiccup, loose spark?/fuel? and even without touching the throttle, bog down. It doesn't die it just self idles down to 3-5mph and chugs sickly along...then for no random reason catches spark/fuel and takes off like a scalded cat, back to full throttle control, game on...then soon loses high power again or may run for 1/2 a day then lose power? Idle response and RPM capablities are unaffected, only throttle response/RPM's when in gear? Is this the VRO, Power packs? Intermittent spark, why? stator, timer base? HELP! I'm thinking of buying two new power packs but my wife is frowning on my "repair by replacement" costs.
Work history:
Compression tested 85/80/85/80/85/75. Fuel pressure tested 3-5psi at all speeds/rpm, (VRO nervously in use), Stator Ohm tested ok, sensor coils ohm ok, ex-mechanic says #2 and #4 loosing spark intermitantly and occasionally, 2,4,6 had no spark? Originally the buzzer buzzed constantly but then last time out Buzzer buzzed intermittantly ever other second. (limped home with E-trolling motor) I have tried swapping over parts from the second motor but ther is no quarentee they are perfect? They didn't change symptoms anyway. I have not checked temp sensors? I have a seloc manual and parts diagrams but have no definitive answer for where to go from here?
When purchased loose flywheel magnets had destroyed the stator and timer base. (supposedly ran great prior, then sat for I guess 3-4 years) I found an exact entire parts motor on Ebay. So far I have resurected and installed new/used flywheel, stator, and timer base, I rebuilt all three carbs, replaced all hoses, tried both VRO pumps, swaped out used power paks and coils, stators, timer base assemblies, and ? from other motors but that hasan't / doesn't change symptoms?
Any thoughts out there? I've read old threads here and have heard everything from new power paks, de-carb, rebuild #6, eliminate the VRO, squeeze the fuel bulb (tried, and only randomly makes a difference.. maybe) and ? Is the rectifier/regulator involved?
Any help narrowing the possible cause(s) would be appreciated.
Thanks!!
Work history:
Thanks!!
