omc 5.7l starting problem
robing
This is either really easy or way to complicated to fix but I'm looking for some help:confused:
I have a 5.7l omc that started fine and then wouldn't.....just a single "click" when you turn the key, both batteries are fine, and I had it tuned up a couple of months ago including points and plugs... Anyone out there have an idea of what went bad??? starter? selonoid (s)? how do I check? I can fix most things myself if someone tells me what to look for and how to do it! Any help would be great...thanks all!
Robin
Haut Medoc
Re: omc 5.7l starting problem
Welcome to iboats.....:)
You could try bypassing the solenoid to see if it is bad....
Be right back.....:)
Haut Medoc
Check out Don's procedure......
I would pay special attention to all of the wire connections & make sure they are corrosion free.......;)
robing
Thats what I was looking for!!!!!! THANK YOU!!!!!
Rob
