Engine stalls when shifting back to neutral
Status
Not open for further replies.
rmurray
I have a Mercruiser 5.7L 260HP Alpha One. The boat seems to be running at the proper idle (fully serviced recently), however, when shifting from forward/reverse into nuetral, the idle drops very low for just a split second before coming up again. 50% of the time, the engine will stall. This can cause frustration when trying to make quick maneuvers at the dock. It almost seems like, during the transition to neutral, the gas gets cut off for just a split second. It seems like it happens more often when coming out of reverse. Is this an easy fix or something more complex? Any suggestions are most welcome. Thanks!
Don S
Re: Engine stalls when shifting back to neutral
The lower shift cable is beginning to get stiff and causing the shift interrupt switch to be held in too long. Now is the time to replace it, it's not going to get any better, but will get worse.
cooter2506
Sounds like a lower shift cable to me. I had same thing with mine. If you have a OEM service manual that can tell you how to replace it or it could be just out of adjustment. But from seeing a bunch of posts on this if it hasnt been changed in a while it should be. Im sure Don (THE MAN) will chime in on this one.
cooter2506
Boy I must type slower than Don, lol he beat me to it
rmurray
Is it an easy fix for an experienced DIYer? I have to get a manual...
Don S
What year is it?
cooter2506
I did mine and it is my first boat I ever owned. Was relatively easy. There is a special tool you need for the nut on the outdrive. But get yourself a manual a good one, not seloc or clymer but an OEM. That will tell you everything you need to know
rmurray
1987
Don S
Here is a link to the online Mercruiser service manual for your drive.
http://www.boatfix.com/merc/Servmanl/6/6covr3.pdf
To use it, just scroll to the last page (manual outline) and click on the LETTER of the section you want to view.
rmurray
Re: Engine stalls when shifting back to neutral ...HELP DON!
Don, I am finally completing this job. I familiarized myself with the cables yesterday, and I want to make sure you were referring to the Drive Unit Shift Cable when you said the Lower Shift Cable? This is the lower of the two cables that are mounted to the shift plate (cables run from remote control to shift plate). I'm just a newb making sure I am not misunderstanding anything. It looks like a fairly simple procedure having read through the manual. Thanks again for your assistance.
Don S
The cable from the shift plate on the engine to the outdrive.
rmurray
Does this require removing the outdrive? I was hoping this was going to be easy.
Haut Medoc
Yes, you will need to remove the outdrive......
Which is not that hard.....(6 bolts on the bell housing & 2 on the trim rams)....
You will need to loosen the two at the front of the trim rams as well....
Removing the drive & lubing the u joints is a yearly task at the very least as part of preventative maint., so ya better get used to it.....
Don't forget to put the shifter in fwd for drive removal & install.....;)
RMassa187
I know this is old, but I have the same issue. Replaced the lower shift cable but the problem persists. I can move the lower shift cable easily and shift the drive by hand no problem. All seems very smooth. Upper and lower cable adjustment seems to be correct. Could the spring on the cutout switch be weak? The shift assist spring is strong so I don’t see a problem there.
Status
