Re: changing tilt motor 1980 omc 140 stringer 400
the drive can be in any position when removing that motor. the motor actually is conected to the clutch pac which is that round thing on the left hand side of the drive, outside, at the bottom. I had to remove the boot and was able to remove the bolts by reaching thru the drive and transom, otherwise it is real hard to reach all the way back. since you have a 400 I am assuming you have a four cylinder, there might be more room to reach from the front, just be careful and don't loose or break the hammer coupling spring
