Re: Good cam choice for a Mercruiser 5.0LX
I agree with Bond-o, but I believe the reason has more to do with power band placement than with water ingestion. The design of the exhaust system is supposed to protect the engine, not the design of the cam. You have to remember, the water and exhaust do not mix until they exit the riser and at that point, on a properly designed exhaust system, the mixture should be running downhill at least six inches to the exit point, be it thru-hulls or the Y-pipe. The engine would have to have some very powerful reversion to suck water in and I would daresay that reversion that strong would give you some problems with running qualities. But, like I've said before, I'm not a designer or an engineer so this is all just opinion.
Stan
