Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
is the shift cable connected at the engine. does it move the shift linkage. could be broken cable, or controller. manually move the shift linkage, and see if it goes into gear.
There is usually no "fixing" a drive shaft. If its broken you need a replacement. Welding wont hold up to the stress. You need do determine what CAUSED the break. Did you hit something or did the lower unit lock up?
