Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
it is 1998 120 force no there is no problems lletting it up and down out of the water. my experice is that when running you trim it until it porpus then let it back down but my motor will not do that it goes back down on its on
your full bulb flatening out could be a bad valve in the fuel pump or as simple as a hole in the diaphram. Dont let the problem with you fuel system go unchecked it can result in lean conditon frying pistons.
