alloffroad
- Jul 20, 2007
- 173
The transom on my dorsett is 18" What shaft sould I go with. It seems that there is a 20" or a 15". If I go 20" I can make a lift for the mount. If I go 15", what are my options?
My opinion from the info supplied is that you can always raise the motor a few inches whereas it would be a lot more difficult to lower the transom to suit a shorter shaft. Remember to have the cavitation plate an inch or so above the bottom of the hull.The transom on my dorsett is 18" What shaft sould I go with. It seems that there is a 20" or a 15". If I go 20" I can make a lift for the mount. If I go 15", what are my options?
