Hi
Started a new thread because the "right in the middle of it" carb question thread was moving way off the original direction. Thanks to all who helped on that one, now for the current dilema...
1990 Johnson 120 V4 with an intermittant coughing/sneezing/dying out at only an idle problem. Sometimes it runs perfectly at an idle, then it will start sputtering and stalling. I've been through the fuel system pretty thoroughly and I'm checking the electrical. New plugs and wires, strong spark on each cylinder when I tested them. Maybe dropping a cylinder, but can't seem to find it. Idle timing dead on and idle speed where it should be. Carbs rebuilt and seem pretty tight and true.
I pulled the flywheel to look for possible worn wires/shorts coming off the stator or timer base and it mostly looked pretty good. There is some corrosion on the flywheel magnets plus the same and what looks like black paint on the stator magnets that I'll clean off. I removed the stator to look at the timer base it appeared to be in decent shape except for a small hole in the side (@ 1/8"+ oval) that I can see rusted/corroded metal inside. The hole is pretty clean, not like a burn through. The rusted metal underneath is one of the pickups. Any opinions on repair/replacement? Money is tight enough that I don't want to change it if I don't have to. I was thinking some liquid electrical tape in the hole to seal it up. How likely is this to cause the intermittant idle issue?
I also found a wire coming out of the stator that had the insulation cracked right where it meets the base of the stator. The wire doesn't look damaged, just the casing. Not that I know what I'm doing.... but I tested the wires coming out of the stator with an ohmmeter. None of the wires grounded out to the base but I did notice that between the two orange wires I had 95 ohms resistance, but between the two yellow wires (one of the yellows had the broken casing) there was only .9-1.0 ohms resistance. Anyone know if this sounds right? Between the two brown wires in the plug there were 400 ohms.
Please feel free to add any input or suggestions for the rough idle. I've checked too many things so far to list them, but throw some out and I'll try the things I haven't checked yet!
Thanks
Thanks
