Hi All
Last year I bought a 19' Sunbird Fish & Ski with a '98 Johnson 115 SPL. The engine was pressure tested and all looked good there, but I've had nothing but trouble starting it since. My starting procedure is 1) pump up the fuel line 2) turn the key on and wait for the initailization confirmation beep, then wait another 30 seconds 3) set the throttle to a bit more than half (I've also tried neutral throttle) 4) press and hold the key in for choke and turn the key. The engine will sound like it's not even trying to start. Eventually taking a few 1 minute breaks the engine will "pop" with some smoke, and 5 or 6 more cranks will start her up. It is intrestsing to note that if it's cool out (early AM around 75 degrees) she'll start right up. If it's hot out (above 80 degrees or so) I'll have the issue. Once it starts it runs like a top for the day. I've pulled the cowl while it's misbehaving and confirmed that the choke is engaging (solenoid is clicking). I've also replaced the plugs and put a fresh few tanks of fuel in her. I'm running 50:1 mix with tcw3 oil, in case you think I've gone and over oiled or run the wrong oil.
Any ideas would be much appreciated!
