Re: 10 hp Johnson QD-21
Help!! I got the carb kit, manual and float ,put them in and the motor started but no water was coming out. Looks like I need an impeller now. Started to take the lower unit apart and the lower unit gears look good but I could not get at the the impeller. Pulled on the spacer where it is housed and got it to come but the shaft stayed in place. How do I get the shaft out?? Looks like I might have dammaged the housing! Does anyone know where I can get one. Also I looked thru the peep hole on the flywheeland the piots look good but the coils look funny. They look like they are cracked? Are they suuposed to look like this. Do I need a special tool to get the flywheel off?? HELP!! What a project!!
