You may have seen my previouse thread which outlines my problem, but in a nutshell it wont go into reverse. I have checked abd adjusted the cables from the remote back, they are fine. The cables in the converter are fine. I pull the cables all the way into reverse and I hear a faint grinding like it is almost engaged but it doesnt.
I have a few more questions before I tear into the outdrive. On the shift interupter switches, when you manualy push the buttons on them should you be able to hear the engine sputter a bit? When I push on them I notice no change in the engine. If these switches are not working will it cause the reverse to not engage?
