1986 25hp mariner,idles well. at mid and full throtle runs well.problem at low throtle just progressing to move forward engine chuggs and runs like there something preventing clean smooth firing equally on both cylinders . i have replaced all gaskets in carb, fuel pump, float, adj, and low speed adj plugs and wires dont help.local johnston marina suggested i visit mercury marina as they said :eliminate switch box! . if my problem is ignition what percentage would be suspect of stator, trigger,switch box,coils to plugs . (engine compression good on both cylinders) any suggestions truly apreciated .
