4runneradam
- May 7, 2007
- 203
This might be a newbie question, but this is my first boat. What's the proper way to set your motor up when towing? I used to put it in the upright position and lock it in place with the little notched clip (have to use a bungee cord on top to hold it down, motor fell down on me once during towing) but I found a metal rod while cleaning out the boat today, and I believe it's a lock for towing. Here's a pic
Is that what it is? Do I have it set up correctly? I have the clasp on the motor hooked around it.
Another pic of the ground clearance with the motor stowed this way.....
Do you think theres enough ground clearance here? Seems kind of low, I don't want to scrape the ground.
