reloading pull cord on 7.5hp
ryan04
I'm picking up a 1960's 7.5 evinrude and the only thing wrong with it is the pull cord apparently came out. That's what I've been told, I'm getting it for free so I'm not that concerned. It apparently runs good, but I just want to know how hard is it to reset the pull cord on one of these things. thanks.
wbeaton
Re: reloading pull cord on 7.5hp
Evinrude didn't make a 7.5 hp in the 60's. If its that old it must be from the 1950's. Post your model number and we can tell you what year it is.
As for the spring, if its not broken I just rewind it by hand and then clamp it in place with the "knot hole" lined up with the front of the starter. Stick the new rope through the knot hole and out the front of the starter. Tie the required knots and install the handle. Its really quite easy as long as you have a clamp.
F_R
If the rope broke when being pulled, it will wreck the spring as it backlashes. So 1st is to check the spring.
Then, see the little 1/8" hole in the rope pulley? Find a pin or nail or something that will fit through that hole.
Now wind the spring up all the way, and back it off one complete turn. Stick the nail through the hole and it will keep the pulley from rewinding. Now at your liesure, feed the rope in. Be sure it goes behind the roll pin in the pulley (not the nail). Put the handle on the rope. Then hang onto it as you remove the nail and let the rope retract.
Do NOT let the pulley get away from you while you are winding it up, or there goes another spring!!!!
All this assumes you have a 1950 vintage 7.5. Very early 7.5s had a wire core rope with a hook on the end. They don't like plain nylon ropes but that is about all you can get.
