Re: parallel batteries
i have been thinking about this for a while.
What i am going to do is
1 cranking batt
1 group 27 trolling batt
1 perko 2 batt switch
1 2 bank charger 5 or amps per bank
Link the motor and all small electrical to the cranking batt, and the radio and all large draes to the troll batt
I will wire the + of batt 1 to the switch and the + of batt 2 to the switch, along with only the + from the motor to the common post on the switch.
If i am correct Then you leave the switch on #1 to start and charge out crank batt, while letting all the high amp draws suck the troll batt dead, leaving your crank batt fine.  You can also switch to #2 while under way to charge batt#2 but like has been mention my takes a long time. or both the charge both at the same time or start from the 2 batts.
the only thing i am not sure of is you may have to link the neg terminals together or split the negative to the 2 batts coming off of the motor.
The use of the 2 bank charger is the assure never a dead batt, worth the extra $100 rather than a problem on the water.
