Re: GPS trails or routes?
The unit will make a trail (purple)for every trip you make it is usefull as you can follow it home without any planing of a "route" should you get lost
or fog ect
You will need to go into the trail menu and turn off old trails or the display will become clutered with them ( you can also make it stop making trails if you want )
If you have a trail it can be given a name and you can pick it and navigate it in forward or reverse as the unit will break it down into waypoints that will use all the GPS functions to tell you time to go, range and bearing ,ect
A route is a preplaned trip that requires you to mark each waypoint and if your makeing a long trip is a very usefull planing tool
I Have had my 3500C for over a year and it will take some time BUT once you understand all the features they work very good and are very easy to use
Tommays
