simpsonian
- Aug 17, 2007
- 3
I bought a used boat and with a 1976 25 hp Chrysler electric start and was told it hadn't been run in a few years but was running fine before. I'm a novice at outboards so I appreciate any help you guys can give.
I bought a manual and replaced the fuel line and tested the fuel pump and that's all working fine. Was getting no spark so 2 nights ago I cleaned the breaker points and got ignition! The motor fired up and ran but would cough at regular intervals (about once every 3 seconds). This caused it to stall at neutral but at full idle it would recover and run for awhile. I have it in my large bin with water and the tail is pushing water out but it seems to be running overly hot to me.
Last night went out to tinker some more but it would not even run for more than 10 seconds. Lots of smoke and the engine would start but die pretty quickly and occasionally jerk / stall and exhaust a bunch of smoke and water. Would it run differently in the lake or would that be a better place to see if I could get it running? Can I try and put it in gear in a tub of water? It didn't seem like a good idea to me.
Thanks for your help. I'm gearing up to really work on it this weekend.
