Trim stuck up HELP fishing trip at 6 am tomorrow!
mayday401
Trim was fine jut put her up 2 hrs ago. When I hit the trim down I hear the pump motor but nothing happens. Is there a special way to bleed ARco 6206
thanks:eek:
wire2
Re: Trim stuck up HELP fishing trip at 6 am tomorrow!
What system? What year?
JasonB
My Mercruiser did that earlier this year. I found it was low on fluid. added 1/8 qt and it worked fine until I got back home and topped it off.
Haut Medoc
Try having an assitant hiiting the down button while you stand on the drive......
Corrosion will do that ....
Of course check the fluid level as well.....;)
mayday401
It was very low on fluid, It called for some special kind of fluid, but i ended up putting machine hydrolic fluid instead, Wiill this hurt it in the long run?:confused:
Don S
You never said what kind of system you have! No year, make, model, nothing.
