before I break this.......(1970 40 HP Merc Rotor)
outboardnut
Does anyone know how this is supposed to come off? It appears to just be friction fit. I've tried putting the heat gun on it and gently prying. I really don't want to bust it!
It's a 1970 40 HP Merc
Laddies
Banned
Re: before I break this.......(1970 40 HP Merc Rotor)
The later 400 the rotor was held with loctite and to get it off without breaking it you had to use a puller after removing the stator you use 2 srews or bolts that are 10-32 by 3 1/2" thru a flat plate puller, the bolts screw into the distributer body and the puller pushes on the crankshaft and you pull the dist. body that takes the rotor off the shaft - piece of cake
outboardnut
never minid I got it.......2 jaw puller or the spark plug tits. Made me nervouse but worked
outboardnut
Thanks Ladies....ignore my above most I wrote it before I saw you replied. You're answer was more of what I was looking for.....the way to do it right. I wouldn't recommend the two jaw puller bit. It squeezes on the tits and is risky. I got lucky and it worked.
Thanks again for helping.
Jeff
