Have an older 15 hp Gamefisher tiller ob that has been reworked with new magneto, plugs, fuel lines/hoses. Motor starts and runs fine and runs very smooth at full throttle. Then after having been turned off for awhile, the motor fires right back up and starts to run fine at full throttle, but then after awhile will start to suck the fuel line bulb flat and eventually stall but will re-start easily and then do the same thing. We replaced the fuel lines and bulb and removed the filter from the tank-end line and also removed the air-intake knob from the gas tank cap, but still starts to suck the bulb flat on the return trip. Any thoughts?
