Ok, I went out and purchased 4 cans of Sea Foam for my 95 gallon tank. I can't seam to stop my bogging down problem on my 200 HP carb Merc (although intermitant). I have added the Sea Foam to the tank, yet would like to pump some into the carbs direct. Everyone tells me this can be a disaster if you put carb solvent directly into the carbs. By passing the oil will fry the cylinders I have been told.
Is this product as good as it sounds or am I destined to tear the carbs down? Anyone out there who has used Sea Foam give me a shout!!
Thanks!, Mitch
Thanks!, Mitch
